Elektrické schéma
Elektrické schéma
Příspěvekod boomer56 » 21.10.2022 19:36
Děkuji, že jsem se mohl připojit ke klubu.
S jazykem jsou problémy ;)
Používám webové stránky DeepL.
Má někdo možné schéma zapojení pro Sportage 2008?
Vůz má benzinový motor o objemu 2,0 litru (1975 cm3).
Typ 2.0 16V 4WD.
Nejlépe v angličtině.
boomer56 Muž
Příspěvky: 4  Témata: 1
Re: Elektrické schéma
Příspěvekod Beda » 21.10.2022 20:02
Hi. Which el. system scheme do you need exactly? It is separated in individual pages for each system in Kia GDS software.
Příspěvky: 8868  Témata: 333
Příspěvekod boomer56 » 21.10.2022 20:37
Thank You for Your answer. So quick response. I managed to download wiring diagrams in Russian, but no idea of the titles :cry:
I'm not sure if those are for my car model. Squish VIN U6YJE5528L.
The winshield washer ( pee boy ) indicator light flashes. There is anyway enough liquid. Probably a removal of the inner cover and an inspection of the connection ahead :x
Other thing interior lights are not working when opening / closing door(s).
This my first Kia ever. Nice car. Just changed engine oil and oil filter for engine. Gone ~297500 km. 3rd gear is little bit noisy if gearing too quickly. In addition replaced air filter for engine as well.
Regards
Henry
boomer56 Muž
Příspěvekod Beda » 21.10.2022 22:58
Here are files for washer level indicator including details of connectors and connectors locations. And interior lights added too.
For opening use for example MS Edge :idea:
Příspěvekod boomer56 » 23.10.2022 12:12
Thank You very much. I am very grateful for the information.
I tried desperately to find the software you mentioned. Is it possible to install firmware for Windows 10 Pro?
Regards
Henry
boomer56 Muž
Příspěvekod Beda » 23.10.2022 13:31
I do not test installation on Win 10, currently have it on Oracle Virtualbox virtual machine where is running Windows XP.
Příspěvekod boomer56 » 23.10.2022 15:28
Okay, should just find the right one software. Do You happen to know how big the file is and can You please show where can I download it ?
I have some old laptops that I can use for only this purbose. And having some xp iso files too.
Sorry about my bad english.
Regards
Henry
boomer56 Muž
