Utahovaci moment krytu hlavy valcov - motor D4FB
Příspěvekod Rostislav » 17.12.2019 15:00
Ahojte,
Idem menit tesnenie krytu hlavy valcov.
Vie mi niekto, prosim, poradit aky utahovaci moment (pripadne aj poradie utahovania skrutiek) je treba pouzit pri motore D4FB (2007)?
Nasiel som tuto info pre iny motor, no nepodarilo sa mi to najst pre motor D4FB, ani ziadnu uzitocnu servisnu prirucku pre tento motor.
Vdaka.
Rostislav Neuvedeno
Příspěvky: 4  Témata: 1
Kia cee'd SW (2007)
325000 km @ 6.3 l/100km
Re: Utahovaci moment krytu hlavy valcov - motor D4FB
Příspěvekod Beda » 17.12.2019 19:56
Tightening Torques
Item
Quantity x N.m
Cylinder block
Engine support bracket bolt
4 x 42.2 ~ 53.9
Piston cooling oil jet bolt
4 x 8.8 ~ 12.7
Drive belt auto tensioner bolt
2 x 18.6 ~ 27.5
Drive belt auto tensioner mounting bracket bolt
3 x 18.6 ~ 27.5
Engine mounting
Engine mounting bracket and body fixing bolt
3 x 49.0 ~ 63.7
Engine mounting insulator and engine mounting support bracket fixing nut
1 x 63.7 ~ 83.4
Engine mounting support bracket and engine support bracket fixing bolt
2 x 49.0 ~ 63.7
Engine mounting support bracket and engine support bracket fixing nut
1 x 49.0 ~63.7
Transaxle mounting bracket and body fixing bolt
4 x 49.0 ~ 63.7
Transaxle mounting insulator and transaxle support bracket fixing bolt
1 x 88.3 ~ 107.9
Front roll stopper bracket and sub frame fixing bolt (10 X 45)
1 x 49.0 ~ 63.7
Front roll stopper bracket and sub frame fixing bolt (10 X 25)
2 x 49.0 ~ 63.7
Front roll stopper insulator and front roll stopper support bracket fixing bolt,nut
1 x 49.0 ~ 63.7
Rear roll stopper bracket and sub frame fixing bolt (10 X 60)
1 x 49.0 ~ 63.7
Rear roll stopper bracket and sub frame fixing bolt (10 X 40)
2 x 49.0 ~ 63.7
Rear roll stopper insulator and rear roll stopper support bracket fixing bolt,nut
1 x 49.0 ~63.7
Main moving system
Connecting rod cap bolt
8 x 12.7 + (87~93°)
Crankshaft main bearing cap bolt (long)
10 x (22.6~26.5) + (90~94°)
Crankshaft main bearing cap bolt (short)
10 x 32.4 ~ 36.3
Flywheel bolt (M/T)
8 x 68.6 ~ 78.5
Drive plate bolt (A/T)
8 x 68.6 ~ 78.5
Timing chain
Timing chain cover bolt (8 X 70)
7 x 19.6 ~ 26.5
Timing chain cover bolt (8 X 60)
2 x 19.6 ~ 26.5
Timing chain cover bolt (8 X 35)
1 x 19.6 ~ 26.5
Timing chain cover bolt (6 X 35)
2 x 9.8 ~ 11.8
Timing chain cover bolt (6 X 28)
7 x 9.8 ~ 11.8
Timing chain case bolt (8 X 22)
4 x 24.5 ~ 30.4
Timing chain case bolt (8 X 32)
1 x 18.6 ~ 27.5
Timing chain case bolt (6 X 35)
1 x 7.8 ~ 11.8
Engine hanger (front)
2 x 19.6 ~ 24.5
Crankshaft pulley bolt
1 x 225.6 ~ 245.2
Camshaft chain sprocket bolt
1 x 68.6 ~ 73.5
High pressure pump chain sprocket bolt
1 x 64.7 ~ 74.5
Timing chain guide (1) bolt
4 x 9.8 ~ 11.8
Timing chain guide (2) bolt
1 x 9.8 ~ 13.7
Timing chain "A" auto tensioner bolt
2 x 9.8 ~ 11.8
Timing chain "C" auto tensioner bolt
2 x 9.8 ~ 11.8
Cylinder head
Engine cover bolt
5 x 3.9 ~ 5.9
Cylinder head cover bolt
13 x 7.8 ~ 9.8
Camshaft bearing cap bolt (mark 10)
16 x 12.7 ~ 13.7
Camshaft bearing cap bolt (mark 9)
6 x 12.7 ~ 13.7
Engine hanger bolt
Front
2 x 19.6 ~ 24.5
Rear
1 x 47.1 ~ 51.0
Cylinder head bolt
10 x (47.1~51.0) + (88~92°) + (118~122°)
Cooling system
Water pump pulley bolt
3 x 9.8 ~ 11.8
Water pump bolt (8 X 50)
2 x 19.6 ~ 24.5
Water pump bolt (8 X 70)
1 x 19.6 ~ 24.5
Thermostat housing bolt
1 x 9.8 ~ 11.8
Thermostat housing nut
2 x 9.8 ~ 11.8
Water return pipe assembly bolt
2 x 19.6 ~ 24.5
Water temperature sensor
1 x 24.5 ~ 34.3
Water inlet fitting nut
2 x 14.7 ~ 19.6
Lubrication system
Oil filter assembly bolt
4 x 19.6 ~ 26.5
Oil cooler assembly bolt
4 x 9.8 ~ 11.8
Oil filter upper cap
1 x 24.5
Oil level gauge bolt
1 x 19.6 ~ 26.5
Oil pan bolt (6 X 20)
16 x 9.8 ~ 11.8
Oil pan bolt (6 X 65)
2 x 9.8 ~ 11.8
Oil pan bolt (6 X 85)
2 x 9.8 ~ 11.8
Oil pan and transaxle fixing bolt
3 x 29.4 ~ 41.2
Oil pan drain bolt
1 x 34.3 ~ 44.1
Oil screen bolt
1 x 19.6 ~ 26.5
Oil screen nut
1 x 9.8 ~ 11.8
Oil pressure switch
1 x 14.7 ~ 21.6
Intake and exhaust system
Intake manifold and cylinder head fixing nut
2 x 14.7 ~ 19.6
Intake manifold and cylinder head fixing bolt
7 x 14.7 ~ 19.6
Exhaust manifold and cylinder head fixing nut
8 x 29.4 ~ 34.3
Exhaust manifold heat protector bolt
3 x 14.7 ~ 19.6
WCC assembly fixing nut
3 x 29.4 ~ 34.3
Air cleaner lower cover fixing bolt
3 x 7.8 ~ 9.8
Throttle body and surge tank fixing nut
4 x 6.9 ~ 10.8
Exhaust manifold and front muffler fixing bolt
2 x 39.2 ~ 58.8
Front muffler fixing clip bolt
1 x 29.4 ~ 39.2
Front muffler and center muffler fixing nut
2 x 39.2 ~ 58.8
Center muffler and main muffler fixing nut
2 x 39.2 ~ 58.8
Příspěvky: 8957  Témata: 333
Příspěvekod Rostislav » 20.12.2019 15:10
Beda Mozes este pls zazdielat aj sekvenciu utahovania skrutiek?
Vdaka.
Rostislav Neuvedeno
Kia cee'd SW (2007)
Příspěvekod Beda » 20.12.2019 18:00
Tady mas cely postup:
Příspěvekod Karens » 20.12.2019 18:05
Lenže on sa pýta na veko ventilov.
Karens Neuvedeno
Příspěvekod Beda » 20.12.2019 22:15
No ani jsem to neprohlizel, vzal jsem to dle nazvu a hele ono tam neni sundani vika :roll: a pro zmenu je u casovani ventilu ;)
Příspěvekod Rostislav » 21.12.2019 06:54
Super, diky.
Rostislav Neuvedeno
Kia cee'd SW (2007)
