spojka na Carnivalech
Re: spojka na Carnivalech
Příspěvekod Proky-x » 24.07.2018 20:10
Děkuji moc
Proky-x Muž
Kia Carnival III (2006)
219000 km @ 9.4 l/100km
Příspěvekod Proky-x » 27.07.2018 20:25
Poprosim o radu jak odzdusnit hlavni spojkovy valec.
carnival III 2006 novejsi model
2,9 CRDi
diky moc za radu Proky-x
Proky-x Muž
Příspěvekod Beda » 27.07.2018 20:42
Vzdyt to mas popsane hned v tom prvnim manualu, ktery jsem ti tam nahral :idea:
Takze predpokladam, ze anglicky asi neumis :| No i tak se to da z toho dokumentu vykopcit a nechat prelozit treba Google:
Kód: Vybrat vše
https://translate.google.cz/#en/cs/CONCENTRIC%20SLAVE%20CYLINDER%20AIR%20BLEEDING%20PROCEDURE%0A1.%20After%20disconnecting%20a%20cap%20from%20the%20concentric%20slave%20cylinder%20air%20bleeder%2C%20insert%20a%20vinyl%20hose%20in%20the%20plug.%0A2.%20Loosening%20the%20plug%20screw%2C%20press%20and%20release%20the%20clutch%20pedal%20about%2010%20times.%0A%0AHold%20the%20air%20bleeder%20body%20not%20to%20rotate%20with%20a%20spanner(A).%20The%20holding%20is%20needed%20when%20the%20plug%20loosened%20or%0Atightened.%0A3.%20Tighten%20the%20plug%20during%20the%20clutch%20pedal%20pressed.%20Afterwards%2C%20raise%20the%20pedal%20with%20a%20hand.%0ATORQUE%20%3A%0A25~29Nm%20(250~290Kgf.cm%2C%2018.2~21.1lb-ft)%0A4.%20After%20pressing%20the%20clutch%20pedal%203%20times%20more%2C%20loosen%20the%20plug%20and%20retighten%20it%20with%20the%20pedal%20pressed.%20Raise%20it%20again%2C%20then.%0A5.%20Repeat%20the%20step%204%20two%20or%20three%20times.%20(until%20there%20is%20no%20bubble%20in%20the%20fluid)%0A%0A1)%20Do%20not%20clamp%20the%20pipe%20of%20a%20concentric%20slave%20cylinder.%0A2)%20Be%20careful%20not%20to%20damage%20O-rings.
Dej vybrat vse a nakopiruj si to do horni adresni radky prohlizece, Enter, presmeruje te to na preklad, neni 100%, ale pomuze to pochopit ;)
Příspěvky: 8858  Témata: 333
Příspěvekod Proky-x » 27.07.2018 21:51
jeste jednou dekuji
Proky-x Muž
Příspěvekod wakantanka » 23.08.2018 10:35
stadt píše:mne menili spojku pred 3rokmi a dnes som bol v servise menili mi štarter lebo pri nastartovani 1krat len cukol az potom nastartoval a mi servisak povedal ze mam zlu spojku lebo mi zabiera na podlahe ,,som mu povedal ze ju nemam ani tri roky niekedy mi ide v pohode radit jednim prstom ani sa nemusim dotykat paky a inokedy mi to ide celou rukou
Mno neviem či to bude priamo spojkou, možno by stačilo nastaviť pri kulise lanovody. Mne to tiež tak všelijak išlo, až kamošovi, ktorému som auto požičal, strelil jeden z lanovodov. Vymenil som cely mechanizmus a potom sa chvíľu musel pohrať s nastavením. Odvtedy ide radenie rýchlostí ľahko a bez problémov.
wakantanka Neuvedeno
Příspěvky: 20  Témata: 2
