Instalaica WolfNCU 4.1 na Kia Ceed 2015 - Gen 2/WinCe7
Příspěvekod davebugyi » 20.10.2018 13:15
Dobrý deň,
Chcel by som sa spýtať, či viete ako treba nahodiť WolFNCU na Kia Ceed 2015 (JD, Gen 2 SatNav, WinCE 7)?
Našiel som návod, ale asi na staršie modely (Gen 1, WinCE 6), lenže už to asi nejde bezproblémovo > teraz pri každom štartovaní treba spustiť manuálne (nemá AutoRun) a treba spustiť aj MyShell, inak neviem ovládať rádio.
Skúšal som aj najnovší WolfNCU 4.1g - ale to isté.
Vďaka.
davebugyi Neuvedeno
Příspěvky: 5  Témata: 2
Re: Instalaica WolfNCU 4.1 na Kia Ceed 2015 - Gen 2/WinCe7
Příspěvekod Sbormistr » 21.10.2018 20:56
Installation method using installer wolfplus_v4.1f.exe:
1. Start the EXE file and choose a language - The default is English
2. Set the path to the memory, where you will install
3. Choose "Full installation" and the type of your processor - This step is important because EXE copies the different .dll files for the different processors:
a) ARM b) MIPS CPU c) PC / intel / amd / cpu
4. Set the path to the appropriate programs - if any. If the programs are added later, the paths are done by .ini and can also be from the menu of the already installed WolfNCU.
5. Uncheck the option "Whether to replace the file"
6. Running the installation and Finish
7. After Finish must be copy the folder Skin from:
This folder is SDMMC\WolfNCU\Skin
and replace the existing one, because it is empty!
After finishing, you must change all values in .ini and set yours!
By default, they are GpsPort=COM2 and GpsSpeed=9600
Příspěvky: 5250  Témata: 25
56904 km @ 4.91 l/100km
